Some weeks I should not have got out of bed. In an attempt to solve my TR4 back fire issue I transplanted all the ignition from my TR3 to the TR4 (dizzy, coil wires and plugs). The TR3 worked fine when I took them out and the parts worked fine in the TR4. Then when I put them all back in the TR3 I could not get the TR3 started.
I set the timing, the point gap etc. I must have missed something but can't figure it out. The car cranks but does not seem to fire at all. If I remove a plug and check it while I crank there is spark.
Is there some way I could have put this together wrong? I kept track (and have done this many times in the past). From what I can see I can't even put the dizzy in backwards if I try. I know there must be a "finger problem" that I am missing.
Winter is comming fast and I have two LBC that don't want to start so I can get them to storage. I should have stayed in bed!
