mrv8q
Hello, listers, I need some advice on my water pump removal. Can I remove the pump without removing the pulley? The manual doesn't seem too clear to me on this. ( I'm impelled to look at my impeller, for some reason.) Can I just back out the 2 nuts and 1 Bolt, and pull off the pump? (I realize the bolt will not clear the pulley). Or, since the WP seems to be working fine, should I not disturb it?
Along a similiar vein, can I replace engine mounts by just jacking up the engine up enough to clear the threads on the mount itself? TIA. Kevin '59 TR3A 58370
