First off, when the previous owner modified the steering, he added a three way toggle switch on the dash for the turn signals. Once I got used to always turning them off manually all was well until last week when I noticed on a drive that I had no flashing light on the dash when the turn signals were on. When I got home I checked and I get one clicking sound on the first left turn flash as well as one flash on the dash, and then no more clicks or dash lights on subsequent flashes, but the left turn signals keep on flashing properly. There is no sign on the dash and no clicks when I flip on the right signals. The right rear flashes at double time and the right front signal does not work. I tried changing the front right bulb but that did not fix anything.
Is it the relay?
I thought I had one with a broken mounting bracket, but I seem to have tossed it when cleaning the garage, so I could not check to see if that fixed it.
Is it the relay?
