I have a problem with the turn indicator on my TR3. It works fine for the left side but on the right side the inside amber indicator only flashes once then stops flashing. The outside light flash just fine, it is just the indicator that does not flash.
I took some measurements and the 'good side' draws 3.011 amps while the 'bad side' draws 2.795 amps. This measurement was taken with the ammeter in place of the flasher unit, so it includes all wire and connector losses. I assume the lower current is not enough to make the flasher unit click over for the indicator light.
My question to the group is, has anyone solved this problem and if so where was the bad connection that is introducing the extra 0.41 ohms. I just thought that if someone has gone through this it would save me the trouble of going to every connector in the circuit and checking.
Thanks in advance.
Adrio
Thanks in advance.
Adrio
