Re: TR3 engine rattle
[ QUOTE ]
Have a 59 TR3 A and when car is first started (first 20seconds or so) there is a rattle in the engine (also seems like the oil pressure does not register immediatly and appears to register at the same time the rattle goes away. Has good oil pressure after that period (about 65)
and continues to be good the rest of the day. Never below about 40.
[/ QUOTE ]
Hi Ron,
I don't want to alarm you but I have known engines to make a light rod bearing rattle under no load, if the oil pressure is missing after start up. 20 seconds is a very long time to build oil pressure. It would appear that the oil system, maybe the filter, is draining back during shutoff. Many oil filters, or their connections, have an anti drain back valve to prevent this situation. I don't know your exact setup, but I would try to correct the situation. "Dry starts" can definitely shorten an engines life.
Large piston skirt clearances can also make a cold start rattle but it takes longer than 20 seconds to quiet & isn't related to oil pressure.
