CCURTISS
While I have my trans out I decided to get a new clutch fork, fork pen, shaft, shaft bushings and a new throw out bearing sleeve for the new bearing.
The new throw out bearing sleeve slides on the input shaft fine before the fork is installed. I then installed the fork, pushed the shaft through then I installed the fork pin.
When I screw it into the folk and tighten it down the throw out bearing sleeve seems to binds quite a bit while I move the level towards disengaging. I loosened the pin a few turns and at the point it became easy to turn the shaft worked much more freely but if I continue to unscrew the pin it then begins to bind again. I screw it back in just a little then everything is free but I can not run the pin all the way in without binding.
My question is, should the fork pin be screwed all the way in tight or is it supposed to be adjustable for this purpose. I know I need to run a wire through the pin and that may be because it is adjustable but the books are not clear on the install procedure.
Thanks,
Thanks,
Hi Guest!
