I got a call the other day from a guy with a TR3 that needs some work done on to get it back on the road.
Here is the list:
-FInish the brakes all rebuilt but 1 caliper needs to be put back on and then the brake system filled and bleed.
-Fuel system cleaned and checked over
-front apron put on
-all fluids changed and filled
-Lube everything
-rebuild carbs
-put the engine pulling on right so timing mark is right
-clean up the interior
-put in the carpet set
-put in the interior
-clean up a few surface rost spots like the battery box
-check the electrical and make sure gauges work
Then she should be ready to get back on the road. He did a frame off in the 80s and the car has sat since then. Should be a fun project for the next couple of months. Lucky the guy wants a driver vs a pristine job. At least that is in my abilities.
So I will be asking alot of questions over the next couple months since I am a spitfire and herald guy vs a TR guy. So thanks ahead of time.
Here is the list:
-front apron put on
-Lube everything
-rebuild carbs
