TR2/3/3A TR3 Tire pressure
RonR
Folks.
Moss Motors' parts manual list tire pressure of the original tire size (22 psi front 24 psi rear) as well as 165 x 15 radials (20 psi front, 32 psi rear.)
Clearly the proportions between the front and rear pressures is not consistent between the original tire size and the newer redial tire size.
Does anyone know where Moss came up with the pressure for radial tires?
What tire pressures are other using for 165 x 15 radial tires?
Thanks.
Ron
Call Moss??
If my ife (with a bad back) were riding in mine, I would lower the pressure to about 20psi, so smooth the ride...but it makes steering in parking lots a bear. Normally I ran 30-32 in both ends, as it made steering easier and more responsive.
