[ QUOTE ]
I talked with a guy up in Stuart, FL who is a TR3 guru, and one of the most accomodating guys I've come across.
[/ QUOTE ]
Hi again,
You might also give Ken Gillanders a call or send him an email. He's been racing and building TRs since he bought his TR2 in 1955. He can probably give you good advice, might sell a high quality T.O. bearing himself. His website is
www.britishframeandengine.com
Ken also loves to chat about TRs and will give you an earful of ideas!
[ QUOTE ]
I would like to convert it to a TR4 clutch and an alloy flywheel in the near future. I was told that that combo would save about 20 lbs....which is quite a bit of rotating mass. Hopefully the old bearing will hold out until then.
[/ QUOTE ]
If your goal is a lighter setup, I think you will want to go to a TR4A flywheel and clutch. The TR4's setup is about the same as you already have. Some TR3 use a shrink-on ring gear, while later TR3 and TR4 use a bolt-on ring gear, but that's about the only difference.
The TR4A diaphragm clutch and its pressure plate are slightly smaller diameter and lighter weight. It uses a different bolt circle, so either your existing flywheel needs to be drilled and tapped to accommodate it, or you'll need a TR4A/later flywheel.
Converting to the later, TR4A clutch and flywheel also has some issues with the T.O. bearing, the carrier and the front cover of the gearbox. All these are different size. The T.O. bearing is a different diameter, length and shape, too. But, it makes it possible to fit a Gunst bearing, if you wish. These are only available for use on the later, diaphragm clutch original to TR4A/250/5/6.
There is a wider variety of parts available for TR4A/250/5/6 clutch assembly, from more manufacturers and generally at a lower cost than the earlier setup. I suppose that makes sense since so many more of the later cars were built and still remain on the road. It gives you more choices.
There were also some problems with the diaphragm clutch, you probably know from reading about TR6 clutch issues. But many of these can be avoided by continuing to use TR3/TR4-style cross shaft and cross shaft bushings (greasable) and TR3/TR4 slave cylinder setup (adjustable with an external return spring). The earlier stuff here simply works better. Some other things, like locating dowels to best align the bellhousing to the engine that were lacking from TR250/5/6, are already on your car. Overall, the 4-cylinder cars didn't have nearly as many clutch issues, even after the switch to a diaphragm clutch. Most of those problems came later with the 6-cylinder cars and are most likely a combination of factors: such as modifications to make pedal effort easier and reduce service requirements.
If you decide to go to a diaphragm type clutch, do some research before you buy and be sure what you are getting. There have been a lot of pressure plates sold that simply have way too heavy spring tension, making for short-lived T.O. bearings. Essentially what happened is some heavier sprung pressure plates for Volvo etc. were being sold for use in TRs.
Better replacements are now available. Knowledgeable vendors like TRF can help you find these, will sell you something pretty close to the original spring pressure (but still a little stronger than original). I think the Borg & Beck, for example, use color coded paint dots to differentiate between the slightly heavier and the much heavier tension plates, but I don't recall the details.
Regarding the flywheel, there are a couple schools of thought about lightening. Switching to alloy is one route. There are a couple concerns here. One is that there really should be additional attaching bolts added, which means modifying the tail of the crankshaft as well. If only the original 4 bolts are used, the holes in the aluminum flywheel tend to elongate over time and the flywheel can work loose. That's not something you want to have happen!
Another concern is that there have to be some sort of steel facings in an aluminum flywheel, for the clutch disk to ride against. Aluminum and steel have different heat expansion characteristics, so the multi-piece flywheel *might* cause problems, over time. If nothing else, it adds complexity and potential for problems.
An alternative approach is to lighten the steel flywheel itself, by machining off material in key places. There are various methods used for lightening, giving results from modest to radical. An advantage is that it choose how much to have it lightened, could take a moderate approach so that the car still has good street manners, but enough to perk up acceleration. Also, the flywheel is still a one-piece unit and all one type of material, with no heat expansion issues. Finally, lightening can focus on the periphery, where it does the most good, retaining thickness in the center, near the fastenings at the crankshaft, for strength. A downside to lightening the old flywheel is just that, it's old and metal can fatigue. Ideally, it should be crack detected to be sure it's safe and usable.
I must admit, I installed an aluminum flywheel on my TR4, before I became aware of the alternatives and advantages/disadvantages of each. The car isn't back on the road yet, so I can't give you a running report. And I haven't yet doubled up the fasteners on the crankshaft, but I will! Test fitting it on the crankshaft showed some problems. The machining fell short and one of the original dowels didn't line up very well.
The cost of an alloy replacement or machining a steel flywheel is roughly the same.
