1)I've got the replacement trunnions(nyloc nut type). The old grease zerks dont want to thread into the new trunnions easily? Did they use a different thread type? 2)For the upper A arm bushes.There is a grease packet with the polyurethane bushes.Does the inner hole get grease as well as the outer part of the bush that goes in the A arm? 3)In the Moss suspension pic they show part (109) 661-560..a shim that goes on the lower wishbone near the washer and thrust washer. I dont recall seeing this shim on diisassembly and it wasnt included in the TRF suspension kit. Is this shim necessary and what is its purpose? 4)I've bought Lubriplate 00 oil for the trunnions.(Dont want to open the grease/oil debate again but I'm sure I read that the trunnions should get oil).Can I just pour this into the trunnion and thread on the vertical link when its on the bench, then install the grease zerk and its good to go? Any advice welcome. Karl
