Hi Peter,
Sorry, I haven't heard any tales good, bad or indifferent about rear bars on solid axle TR4A. I hope someone chimes in with some real-life experiences.
Yes, I can understand why you wouldn't want to modify your car, and then not like the results. It's *possible* a rear bar works better on solid axle TR4A than on a solid axle TR4, because of the additional flex in the 4A frame. But I can't really say one way or the other.
I think your best bet would be to try a modest size front bar, like the 3/4" you mention, without a rear bar and see how you like it. If it does the job and you feel understeer is about right, great. If there is too much understeer, then you can think about adding a small bar at the rear, or you can try many other things first. Raising and lowering tire pressures or ride height, front and rear, changing front/rear weight distribution, adding wheel spacers at either front or back, changing alignment, adjusting shocks or using harder or softer springs can all have an effect.
One reason for trying just the front bar first is that a little too much understeer is generally safer and more controllable than too much oversteer.
What I've heard numerous times firsthand from owners/drivers, plus read about in books and magazines, is that a rear bar on live axle TR4 (and earlier) usually induces too much oversteer. Worse, some said it was unpredictible because the car becomes unforgiving and sensitive to road surfaces, reacts differently on wet/dry, slick/cobbly roads. So most don't use a sway bar at the rear. Heck, even the Leyland Competition Prep manual makes no mention (that I can find) of a rear bar on TR2-4. It does detail front bars on TR4 and gives extensive info about making/installing both front and rear on IRS TR4.
The added harshness from heavy rate springs and sway bars might make for a pretty bumpy ride. But, someone planning to head out to autocross on the weekend might not notice or object to it!
Another consideration, a front bar in conunction with a limited slip diff might induce a lot of understeer. So, if a TR4 has both installed, a small rear bar (9/16-5/8") might be usd to counteract that. However, the TR4 in the Competition Prep manual was fitted with a 1-1/16" front bar, LSD, and, apparently, no rear bar.
These were mostly racing situations and vary to some degree by personal preference or driving style, are different in one type of driving or racing than in another, and even with different tire and wheel packages. The TR4 chassis is a little more flexible than TR2-3, too. But, I drove my car for years with no sway bars and close to stock rate springs and it's a pretty rigid ride.
In fact, I recall talking to someone or reading somewhere about successfully taking an entirely different approach to setting up a racing TR4, more like a Morgan would be, using no sway bars and allowing the chassis to flex quite a bit. Tuning was done with the springs and shocks.
Street cars might not need or want sway bars at all. A lot of handling improvement can be accomplished just by going to urethane bushings, different shocks or playing around with spring rates, etc., or maybe installing a LSD.
Like you, I'd like to go autocrossing in my car, but still want to be able to use it on the street. Let us know what you think of your brake setup. I've thought about doing something similar, probably using two Girling brake MC of different sizes to balance front and rear, or maybe dial it in with a just a balancing valve on the rear circuit.
Cheers!
Alan Myers
San Jose, Calif.
'62 TR4 CT17602L
