Hey, I guess I'm building up a little reputation as a TR3 modification guy (widening a TR3 body four inches...), so I'll tell you what I did to get my other '57 TR3 to run cool. I decided to update the very ineffeciant (hole or no hole) radiator. I used a Chevy Monza cross-flow triple-row type and had it narrowed to fit in the original location. The cross-flow design and number of rows makes this so much better than the stock unit. Behind this I mounted an after-market electric fan. These are great units and spin very fact and move alot of air. The 'cool' thing to do is mount a temp sensor in-line somewhere to modulate the fan on/off. I just have a manual switch. These fans mount easy with straps pulled through the rad core itself. After this I was now able to machine off the heavy lump of original fan extension from the front pulley assembly. If I remember I was able to use the original starter crank center bolt by simply cutting it to it's new length and threading the cut end to match the crank. I run a Chevy 180 F degree themostat, which is an unbelievable perfect fit. I thought I would also use another pulley on the water pump to get it to turn faster, but this proved not to be needed. I live on the West coast of Canada, and although nowhere near the temps you get, we get up there in the summer. I can sit in stuck traffic for hours and the temp. guage sits at 185 F. It has worked out very well for me, and although not stock, in a TR3, it's hard to even find the radiator! Oh, I run a 15 lb pressure cap and an over-flow bottle, which is mounted behind the rad, where I can top up coolant, if needed, without having to open the rad. itself. If you can stand the idea of an American part under the hood, this will keep your car cool. I'm even more disadvantaged because I've got the 'small mouth' grille, and my motor is tweaked- 2.2 litre, cam, headers, etc... Good luck!
