TRclassic3
I'm in the process of swapping out a TR4 (or 4A not sure) tranny in the 3 for TR6 overdrive. While searching the forum archives I came across a previous discussion of the switch. It was noted there, and I have noticed on others cars as well, that the word overdrive should be facing the wheel. I found that my dash already had the hole available and also noted it's "D" shape. This of course corresponds to the D shape of the switch shaft. However, when mounting the swith, the word overdrive faces out and not in. Is this something that can be changed by taking the switch apart? In all honesty, as originality is secondary to function for me, I'm tempted to leave well enough alone. I assume this would mean that switch up for on and down for off. Thoughts?
