bluemiata90
I'm in the rebuilding stage of my TR3 engine and am very confused about the oil pressure line connection to the oil filter assembly and the oil pressure gauge. I found a small SOLID threaded stud that the banjo connection appears to attach to on the oil filter assembly. I even ordered a new stud, washers and nut for the same assembly area and the stud is SOLID. How can the oil flow into the banjo connection if the stud is solid. I figured the new one would have a hole through it to allow the oil to flow. My question is where do I connect the banjo connection from the oil guage line to the engine and should this stud be solid. I'm very confused and any help will be greatly appreciated.
Hi Guest!
