TR2/3/3A TR3 nose badge
Gordon_Dedrick
I have one of the unusual badges that is blue/white but has the black band on the bottom instead of blue. Some of the enamel is chipped. Does anyone have a resourse for enamel repair?
Gordon
That's a real rare badge from what I've been told and was only fitted to a narrow range of 59's. My late 58 also has the 3 color badge but I believe it's incorrect for my 58.
That said, I can't help you with the repair - the enamel is really cloisonne - from wiki:
<span style="font-style: italic"><div class="ubbcode-block"><div class="ubbcode-header">Quote:]Vitreous enamels in the different colors are ground to fine powders in an agate mortar and pestle, then washed to remove the impurities that would discolor the fired enamel. Each color of enamel is prepared this way before it is used and then mixed with a very dilute solution of gum tragacanth. Using fine spatulas, brushes or droppers, the enameler places the fine colored powder into each cloison. The piece is left to dry completely before firing, which is done by putting the article, with its enamel fillings, in a kiln. The enamel in the cloisons will sink down a lot after firing. This process is repeated until all cloisons are filled.[/QUOTE]</span>
Just do a google search. There are plenty of places that do that sort of work. Here's one.
FYI -- my '59 (built 4/15/59) also has the black bar badge.
As mentioned, a rare thing -- perhaps the initial badge used when changing from the red & black? Possibly the third color costed more and was changed to a 2-color badge for that reason. Wouldn't have been the first time Standard changed something to save 5d.
