Hi tr3 people does anyone know if the fuel line that goes from the tank to the fuel pump is different from a 1958 tr3 to 1961 tr3? I know the 58 has the tank out let in the middle of the tank and uses a two piece metal line and the 61 tank out let is toward the driver side of the tank. The problem I have is the 61 I am restoring was a basket case and I cannot tell if the line is original. The line in the 61 uses rubber at both ends and is a single metal piece. I have owned and driven a 58 for thirty years, but this 61 has some subtle differences. I know the bodies and things changed a little over years, but Moss lists the fuel lines as the same.
Thanks sp53
Thanks sp53
