Hi Guest!
Do you have the original US-spec lamps now? If so, then a regular 6014 sealed beam bulb will work fine. It draws slightly more power than the stock 6012 (which are NLA AFAIK) but the stock wiring will handle the current.
You could also go for an H4 conversion. I don't know a NAPA number for the conversion, but lots of folks sell them. Once you have the conversion, then if one burns out you only have to replace the inner H4 (aka 9004) bulb, which is readily available at any auto parts store. The lowest power (and most common) 55/60 H4 bulbs draw just a little bit more power than the 6014, but again the stock wiring will handle it with ease.
It's been longer than that, I bought a pair in 1998! Nothing wrong with them, but they have flat faces (which looks a little odd to me) and I didn't really like the light pattern as well as I did the ones I had before. So this time around, I'm going to try the convex face conversions from TRF. Haven't fired them up yet, but they look nice
I'd have to double-check, but ISTR the ones from Bus Depot do not have either SAE or "E codes" on them, meaning they aren't approved for highway use in the USA or Europe.
I think it was part of the general drive to reduce fuel consumption and emissions. Blending the headlight surface into the body lines reduces wind resistance. At least I believe that was the argument that the auto makers used when they finally persuaded the US DOT to drop their requirements for standardized headlights. Plus of course, plastic is a lot cheaper to make than glass.One more thing. Who ever got the idea to put plastic covers over the headlights? My Accord left side one is completely fogged over. I got one of those kits and it only made the problem worse. I hear the replacement covers are expensive.
