Hey guys
What is the bottom fitting size/type for the TR3 fuel tank (fuel line outlet). I bought a tank from Jorge (EBay) some time ago and now that I'm fitting the tank, I see that the tank I purchased has a half coupling brazed to bottom for fuel outlet. It is a straight coupling, 1/2" fine threads. Not NPT.
My fuel line is 5/16" inch and has a female compression fitting on it. So, I need the male end of a 5/16th compression fitting and all I have is a tank with straight (not tapered) 1/2" female threads.
Not sure how this would seal up? Maybe with a fiber or nitrile washer?
Am I missing an adapter? - seem obvious that I am but I thought I'd check with you all and see what to do here.
Thanks
Pat
