TR2/3/3A TR3 Fuel Tank Filler
oxendine
Does the filler spout on a 1960 TR3 have a rubber grommet between it and the rear deck? Parts book does not show one? I thought there should be something.
Thanks, Donnie
Yes it does, its a small section of large diameter rubber fuel hose.
I got one at Moss a while back, I would just measure it up and check with your local machine shop, its worth a shot.
It's got the fuel hose, but there should also be a couple seals above and below the deck, if you have the earlier screw-together spout.
John
For the later one piece gas cap, a rubber grommet is needed to waterproof the hole in the rear deck. Moss Motors list it as part 680-575.
Viv.
