martx-5
Well, I have developed a problem with the TR3 engine. My procedure to start the car has been to pull open the fuel shut off valve, prime the carbs with the lever on the fuel pump, pull out the choke, turn on the ignition and push the starter button. A second or so later, the engine is running. However, I've developed a problem after running about 30 seconds or so. The engine drops the two back cylinders. I opened the float chambers and noticed the the back float was down...no gas. The front was OK. Stop the engine, re-prime the carb floats with the lever, and the same thing happens. Thirty seconds later, it starts missing, and the back float is dry. I did notice, that while priming with the lever, it took a lot more movement to feel the pressure of the gas going into the floats...way more then usual.
The fuel pump was rebuilt awhile back with a kit from TRF (there is only about an hour and a half on this engine). I've read about bad diaphragms for these pumps. Is there a possibility that I have a bad fuel pump diaphragm??? What do I look for when I take it apart??? and Who has good rebuild kits??? If, this is the problem.
