Yeah, I've had a similar problem. Gets worse the longer you keep your foot off the clutch pedal ... I got to driving with my foot on the clutch so the hydraulics wouldn't bleed down. In my case, it was a bad return spring on the slave, combined with a broken taper pin that made the adjustment really bad. The slave still had enough travel to release the clutch, but at first the piston would only return as far as the clutch would push it. From that position everything worked OK. But if I drove for any length of time without using the clutch, the return spring would gradually push the slave piston home and then I'd have to pump the clutch up again before it would work.
The other possibility is a broken spring inside the MC.
Randall
