Some would argue that the TR3 should have had relays, which can help take the load off of other components such as switches in high-current-draw circuits such as headlamps or horns. But like you, I've had hands-on experience for many, many years with orginal electrical equipment on various British cars...equipment that continues to function as it did when new.
And I can compare a number of cars with otherwise almost identical components. I've Heralds and TR3s with no relays in (for example) horn circuits, and the horns work as well as they do on Spitfires that did have horn relays. Over the years, I've also dealt with any number of such cars that had been, uh, "modified for safety" with addition of relays and goodness knows WHAT else. Not being an EE myself, my usual approach is to undo whatever Rube Goldberg-type "fix" /ubbthreads/images/graemlins/hammer.gif was applied and return things to original...after which they work just fine again. /ubbthreads/images/graemlins/grin.gif
Sometimes I wonder which is worse: well-meaning but sometimes poorly thought-out additions, or the classic "wood screw replacing a fuse"? /ubbthreads/images/graemlins/eek.gif
