I've seen alot of talk about balance problems with the TR3 driveshaft. I never had a problem in the past with driveshafts, but this is my first TR3. Or is the problem only if you use one of the conversions. I understand that if the shaft is damaged or bent you will have vibration problems. It will be some time before I use mine. It has been cleaned, and rebuilt but I did not have it balanced. Should I?
Almost forgot to mention that I'm using the stock trans, and overdrive unit.
