I am currently attempting to remove the lower hinge and have been unable to remove the last screw holding the bottom hinge. I have removed the upper hinge screws using PB Blaster penetrating oil and an impact screwdriver. The impact scredriver treatment resulted in the head of one screw breaking in half. I then used a drill to remove most of the tapered portion of the screw. I then used a punch from the drivers side and broke one of the spot welds. Using vise grips from the other side, I was able to remove the captive nut. The last remainning screw will not release. Should I use an torch to heat the screw or should I drill and drive it out as I did previously? The downside of drilling is that it damaged the tapered opening in the hinge. The A pillar is in good coacetylenendition.
I plan on using these captued nuts from McMasrwe-CARR item # 90955A113 to replace the factory ones. Would this be the best approach?
