dumb question
In an attempt to adjust my timing I found that my distributor won't budge an bit. It seems completely seized on there. I sprayed a lubricant around the base after I had loosened the body clamp bolts and pinch bolts and have let it sit overnight. I've tapped it to create some vibration and after two days of this it still seems as immovable as ever. Any one know any tricks for this. I'm not a mechanic so please respond as if you were trying to explain this to an idiot.
Thanks for your help.
