TRclassic3
I was using some directions on setting the static timing by using a 12 v lamp(continuity light) to identify the moment the points open. With one end to ground, and the other to the moveable points arm the lamp would light when the points begin to open. Points closed, no light. This of course with the ignition switch on, motor not running.
Now following that concept, does it make sense that you could do the same basic test using a multi-meter set to voltage (say 50) and the ignition switch on, one lead to ground, the other to the moveable arm. Should you only get voltage with the points open? When I do this I get 12 volts both with the points open and with them closed.
Comments please
Comments please
