I am very glad to report that I got my original TR3 turn signals working with the help of all in this thread. It turns out I had a bad wire, bad switch, bad flasher, so it was more than due for an overhaul.
There are two more questions that I have now that are less vital but still nagging me. With the three new tiny 'grub' screws in the steering wheel it does a great job of keeping the control head firmly on the wheel but the head still turns right along with the wheel. I was hoping the 3 tiny screws would take care of that. I am pretty sure that what is happening is that the pipe like thing that is about 6 inches long and is solidly attached to the head is just turning inside the stator. There is supposed to be a key that prevents this inner tube attached to the control head from turning that I obviously do not have right. It did take some prying to get the thing off (head and attached pipe) but when I was reinserting it it just slid in with no positive 'lock in' feel. The only thing that might represent a 'key' on this 6" tube was a series of indentations, maybe 5 or 6, at the end. Is this the 'key' that is supposed to keep it from moving? At the bottom of the steering box I am unable to get the nut that the wires go through with the 'acorn' like piece of brass that should be holding in the steering oil tight. Either the threads on the stator or the nut are stripped some way because I can only tighten it up to a certain degree and then it loosens up again. I am hoping that it is the nut that is stripped and not the thread of the stator.
I am guessing that the real problem might well be that the entire stator tube is turning freely inside the steering column and the 'key' towards the control head may be working but to no end. Then again pulling it out of the stator was sort of a struggle and putting it back in did not feel at all like a snug or tight fit. I am not that worried about the control head turning with the wheel as it has been doing that for a while but if I cannot get the 'gland?' nut at the
bottom of the steering box tight I don't think I will have a chance of getting any oil to stay in there to lubricate the cam and peg. I am very much hoping that all it will take is replacing the nut at the end of the steering box where the wires come out.
Has anyone dealt with these same problems before?
Thanks very much,
Jim Lee
