TR2/3/3A TR3 Clutch slave bleed screw size
RedTR3
Simple question: Could someone tell me the thread size of the bleed screw on the TR3 clutch slave? I want to order a Speedbleeder fitting. Also, is replacing this cylinder pretty straightforward or are there any gotchas along the way? Thanks, Tim
Sorry do not know the thread size of the bleed screw but the clutch slave cyl. install is pretty straight forward. Make sure to adjust with the proper free play in the pushrod shaft and bleed the slave according to manual instructions.
3/8"-24.... /ubbthreads/images/graemlins/cheers.gif
Working with LBC's means that there are ALWAYS gotcha's along the way. What starts out as a 30 min project some always turns into a 3 or 4 hour project. However, the joy of getting it done makes it worthwhile!
Good Luck, Tinkerman /ubbthreads/images/graemlins/thumbsup.gif
the one thing that I've learned about any 30 min project is: Never start it in the after noon or when hardware stores a closed.
