Last week, I posted that the pressure in my clutch would not release. It was the concensus of this group that I had broken spring. I took it apart and discovered that the spring was fine. It turns out that the problem was the spacer at the end of the internal components. It is part 30 in the diagram.
The "legs" of this part are now flush with the end of the plunger. Because of this, the plunger cannot retract and the fluid is not releasing back into the brake fluid reservoir. All of the pictures I have seen shown the spacer extending beyond the end of the plunger.
I see Moss has a part number for this item, but it is not available. Other than ordering a new master Cylinder, are these available anywhere? Does anyone have an extra? I see BP Northwest has a kit with one, but it specifies it is for a TR4, but I am assuming that it should also work for the TR3. Does anyone know if this would be compatible. It has the same internal 3/4" dimension as the TR3.
Thanks for your help.
Hi Guest!
