HI all -- Question about replacement of a clutch disk and pressure plate for a TR3 -- I assembled it just fine to the flywheel, but then I began wondering if it is possible to have the pressure plate 180 degrees off? Is there a right and wrong way to bolt the pressure plate to the flywheel, or is it OK as long as it corresponds to the dowel pins? Also, I plan on giving the pilot bushing and splines a thin coat of lithium grease, unless someone tells me otherwise.
Just need to get the right crossshaft now, ordered one years ago, but found out last weekend it was for a TR6!
And since you're replacing the plate, there's nothing you can do about it now even if some misguided soul did balance them as a unit.
