Lukens
Greeting Brothers,
I'm up in Ohio visiting family. I've got a clutch situation that I'm not sure how to handle. I've developed more free pedal travel than I used to have. With the pedal up, the master is fully extended and I can't push it's piston in (from under the bonnet). However, I can manually push the rod on the slave back into the cyclinder maybe 1/2". Depress the pedal and the rod comes out and disengages the clutch. Release the pedal and the rod returns (with the spring connected) to it's "home" position. However, from this position I can again with only "slight force", force the rod and piston back into the slave... no movement up at the master.
Am I compressing air? Do I need to bleed the line? Or am I pushing fluid around a leaking seal in the master?
I apologize for this vague description. Maybe through dialogue I can explain it more clearly. In the mean time I'll go buy some tubing and try bleeding it.
EDIT: Maybe a simpler explanation is to say that my slave cyclinder behaves as if the spring itself is not stong enough to fully retract the piston. ???
Russ
Russ
Hi Guest!
