Deleted member 451
TR3 has a problem setteling back to idle. When playing with it yesterday I saw that the front carb piston was sticking. Tries everything I could think of including switchint the chamber and piston with the rear carb. Front carb still stuck. When I moved the choke lever the piston fall into place. This makes me think the Jet is not centered causing the needle to stick.
Give me your thoughts please.
Hi Guest!
