emmett1010
Hi Guys; two quick questions.
My front Carb float bowl on my H6 carbs starting leaking where the float assembly is attached to the bottom of the Carb. I tryed to snug it up some, and tore the rubber gaskets beyond use. I installed some copper compression washers, and it doesn't leak anymore, but I wondered if this can cause later/different problems?
The second question is the wiper motor wiring. My car is converted to negative ground. After complete disassembly it would appear that the motor terminals 1 and 2 are designed for a positive and a ground. Number one has a ground interuption for the park switch. Since it will not start without a ground, I assume that a switched ground, on the dash, would solve this problem. Number two terminal should have a hot whenever the key is on.
This means that I must take my wiper switch and disconnect the hot, and run the unswitched side to ground.
Is this correct, or am I missing something?
Thanks Emmett
Thanks Emmett
