TR2/3/3A Tr3 breather pipe
sp53
This might be my second most stupid question. On a tr3 when removing the oil filter do you also remove the breather pipe, and if so do you put a little compound around the pipe when it is reinstalled.
George
I've never heard of removing the breather pipe during an oil change. The oil change is tough enough without adding any additional steps! Maybe someone else knows something that I don't (I'm absolutely certain that most people know several things that I don't), but I'd leave it alone.
Nope - never had to remove the breather pipe even with the PITA original cannister filter. With highly-reccomended (in my opinion) spin-on adapter you can even change the filter from above.
For the orignal-obsessed I think Geo has the paint color to spray the spin-on filter green so it looks pretty darn original.
If you think you need to take off the breather pipe to get the cannister off I wonder if yours is bent??? There is nothing serviceable in the pipe itself and nothing to change - I don't even think there is any screen at the top of it.
I've also been told by no means should you change the length or move where it goes because the air travelling past it at speed creates a specific vacuum. Changing this pipe in any way leads to very messy results. But then again I seem to recall a couple of SCCA TR3's with some kind of hose attatched that ran up into a empty oil bottle wedged between the battery and the frame in the battery box.
I guess the reason I asked the question is that the filter is so difficult to remove and get back on without stripping the aluminum housing that for years I would pop off the breather vent pipe when I changed the oil. I just wanted the extra room to work. I just accepted the oil blow by as part of open crank case ventilation system OCV. Then I guess I was boarded and was trying to stop some of the oil leaking and figured that perhaps the area around the vent pipe where it goes into the block was sealed at the factory, and if I dynamited the breather pipe back into block it perhaps would slow down the oil leaks. Sealing the breather kinda moved the leaks toward the back and did slow it down some, I think. I hate oil leaks. I think that is why I own a tr3 it gives me something to hate. Seriously, mine really does not leak that much but oil leaks do bug me. I have the original filter set up and like it that way. I guess next time I will leave the newly dynamited breather pipe on and see if I can get the filter on and off without too much trouble.
George
