Anybody have a spare outlet fitting from the bottom of the brake reservoir? I should explain....the PO had installed a 4A clutch master which has it's own reservoir. I would like to switch back to the original clutch master. The odd thing is if you look at the bottom of the reservoir you can see that the hole for one of the outlets appears to have never been punched out! Anyone have such an outlet on an old 3 brake reservoir sitting in their parts bin?:joyous: I like the new reservoirs that Moss has but would rather put the money towards a new clutch master.
