Need a bit of advice: I appear to have my bonnet set pretty well with a minimum gap at the front apron and slightly larger at the cowl. With this set up the edge of hood to cowl clearance (when opened) is about equal to an index card or two.
With tape on the edge of cowl it will gently rub the cornr of the cowl lip as I open.
The small clearance occurs only between the hinges- Outside of hinges to where hood meets fender are probably 3/16 to 1/4 inch though I have not measured. The center seems to set a little low, yet if I add additional gasket under hinge it seems to raise outside corners of hinge above cowl.
My fear is that the bonnet (between hinges)"flattened out" somehow. As an experiment I place a small piece of styrofoam halfway between hinges and it seemed to help on the closed and though it did not change the index card clearance it did not rub the tape as it started at a higher point (if that makes sense)
All advice welcome.
MERRY CHRISTMAS!
Griff
All advice welcome.
MERRY CHRISTMAS!
Griff
