There was a previous thread on a 3 that had a high idle and was running rich. I wonder if that person ever tracked down the problem? I have a 3 with a mild street cam and header....runs fine except for a high idle(around 1200 rpm). I've opened the valve gap up to .016(they were at the stock .010) and that seems to have helped. The SU's are set up pretty good and performance is fine...except for the sooty plugs which would indcate a rich condition. Without mucking about too much with the carbs could I just lean out the mixture one or two flats to see if I can get the light tan plug colour that I should have? Any suggestions? Karl
