I am dissembling at Triumph overdrive transmission (A type) for a rebuild. I have rebuilt a transmission in the past, but not with an overdrive unit.
I have removed the initial items following directions, information and reference from a Haynes manual, VTR maintenence pdf's, and an official Triumph workshop manual including the complete overdrive unit and subsequent rear adapter plate.
The overdrive "pump cam" that locates on the rear of the transmission mainshaft (behind the rear mainshaft bearing) - How do I remove it from the mainshaft? The only information I have found says "remove pump cam from mainshaft", or no reference at all to this issue. Do I need to remove it for the rebuild? Do I heat it for expansion to remove? How does it stay set in place in relation to the mainshaft (i.e. so it doesn't rotate on the shaft.
Any help or direction on this would be greatly appreciated.
