prb51
Gents,
I wasn't happy with the vibration I was getting after putting the Toyota 5 speed in my 3. The car vibrated some before (what 3 doesn't) but after the change over it was more pronounced.
Since we used the existing stock flywheel/clutch basket (only changed the clutch plate) we figured the only thing it could be was the driveshaft.
We had used the same type of collar that the HVDA kit uses in locking the driveshaft in its most extended position...for those that don't have the 5 speed the Toyota tranny takes up the slack at the input shaft so you need a solid driveshaft.
Anyway, a 53 year old driveshaft fully extended and locked by that collar had to be the culprit.
Bill took his to a specialist and he tested his TR3 DS on the balancing machine and found it had 10 thousandths play or wobble in that configuration. There is no way to balance a DS that wobbles at a joint. You figure that when fully extended (as the kits call for) you've less mating material and then take into account the wear factor for our old DS's.
So he made us a solid DS with a Toyota front spline and a mating surface for the TR3 rear, all new u joints (common flaps availability) balanced to 100+mph/painted and ready to go.
Because the front spline section is not detachable I had to remove my tranny cover for clearance and you only use 4 bolts for the rear.
I couldn't believe the difference, I suspect mine was out of tolerance further than Bills as the reduction in vibration was huge...from idle up to 75 mph today. Just awesome and I don't have to worry about the collar coming loose (mine had drifted 1/4 in from installation) and having a flying driveshaft to deal with.
Here's the pics.
https://i216.photobucket.com/albums/cc138/prb51/DSC01260.jpg
https://i216.photobucket.com/albums/cc138/prb51/DSC01261.jpg
https://i216.photobucket.com/albums/cc138/prb51/DSC01262.jpg
Here's the pics.
