Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
Has anyone on the forum ever tried to install power steering on a TR6?
The recently completed 74 TR6 is looking great...really fun to drive...but steering is a little too hard.
Any input and or links greatly appreciated.
Can't imagine a TR6 with steering hard enough to need power assist. I believe I would recheck the suspension. With the car up in air, is the steering still a little stiff?
I am a little surprised by the comment too, I would check to make sure there are no issues with the steering and suspension before I went to a power set up, what size tires? wider tires will certainly up the effort a bit.
Usually pwr str not needed until car hits 3Klbs. Check rack and joints for proper lube before trying something that isn't needed in a light weight car.
Tire size is 185 R 15.
The Rack & Pinion I got from VB...and this is 2.5 turns VS the Moss 3.5 turns.
Noted...that before the rack was installed tires turned quite freely.
Granted that we may have a suspension issue...will follow up on that.
Any info re the electric power steering?
Thanks for the replies
Gil NoCal
I've got the quickrack from moss in mine, and a small 13" wheel, and while it turns harder in parkinglots, it's not bad at all, and is infact better than the stock rack was on my car. Tire size has a lot to do with steering hardness at low speeds too. I'm using 205/70-R15 tires on 5 inch wire rims.
