TR-4 Transmission
iI just happened across this, you should post it in the Triumph Forum where you'll get response. More specifics i.e. does it grind, make noise, drive and sound ok when driving. If all gears I would check first check the clutch hydraulics and slave cylinder adjustment first, it could be dragging.
