There's a hole on he passenger side into the engine room. Its down below the starter relay. It is punched through with a lip around its edge. Its too small for the hose to easily pass through - it takes a real force-fit.
John
For earlier TR3As, that location had a blanking plate/rubber gasket closing off the redundant hole for the steering column for RHD cars - the drain tube fed right through the middle of the rubber gasket.
