angelfj1
Need help. We ordered (and received) an upgraded water pump from a supplier in England. This pump has a different impeller (5-vane). It is claimed to deliver better flow and enhanced cooling. (we will see???) I did this because I wanted to use an original radiator with the hand-crank hole. Having the hole reduces cooling because some of the tubes are closed off. The theory was for the enhanced water pump to make up the difference. Here's the problem. The pump arrived without a pulley. The instructions say that the original pulley may be used. The original pulley was an interference fit onto the original water pump shaft. The new shaft is undersized to the point that the pulley easily slides over the shaft. I understand that another arrangement was used where the end of the shaft was threaded to take a nyloc nut. Does anyone have a suggestion? :eeek:
