When posting a classified ad, you MUST select a prefix from the drop-down next to the subject line. If you don't you will get an error and your ad will not be posted!
Here is one in NY ...I am sure if they can't assist you, if you ask they may be able to point you to a local dealer....or check with local fire departments for where to go....
After looking at the two hoods I have in the garage,one flat and one raised hinges,both have the front and rear braces tight to the skin all the way across.No way any felt or anything could be put under brace.So my bonnets are different or I am not understanding.
Tom
