That would be the one Andy is talking about. It replaces the original cap and doesn't look the same. Don't see any reason it couldn't be fitted to earlier cars, but you'd have to add the grommet and perhaps enlarge the hole. Might need a new (longer) connector hose too.Moseso said:Victoria British has one on this page but they say it's for TS60000 and later.
TR3driver said:PS Not whining about gas prices, just stating the obvious.
mrv8q said:TR3driver said:PS Not whining about gas prices, just stating the obvious.
I saw something positively scary tonite: Regular gas $4.83. Premium $5.33 Diesel $5.83 Yikes!
Sorry, I'm working from memory here, and that's sometimes NOT a good thing for me. ISTR that the "big" difference between pre- and post-TS60000 cars' gas caps is the fact that the earlier cap has an outside threaded neck and a large nut to hold it to the tonneau panel. The later caps are more like that of Spitfire and TR4, where they're primarily held in by clamp to the tank connector hose. Does that sound right?TR3driver said:That would be the one Andy is talking about. It replaces the original cap and doesn't look the same. Don't see any reason it couldn't be fitted to earlier cars, but you'd have to add the grommet and perhaps enlarge the hole. Might need a new (longer) connector hose too.Moseso said:Victoria British has one on this page but they say it's for TS60000 and later.
We've had this debate before; and I still don't know the answer. There were at least two different gas cap assemblies fitted to TR3/A that did fasten to the body. All but one of my TR3/As have been pre-60K, and most of them had the even earlier type of cap where there is a casting below that the upper casting screws into. The one that was stolen was this type, the thieves simply unscrewed the upper cap from the threaded casting inside the body.Andrew Mace said:ISTR that the "big" difference between pre- and post-TS60000 cars' gas caps is the fact that the earlier cap has an outside threaded neck and a large nut to hold it to the tonneau panel.
