Need some help...
1 I am rewiring my TR3 and I don't see were terminal E on the regulator is connected. The wiring diagrahm leaves things in mid air??
2
Polarizing the dynamo (negative ground) has not worked so far.
Used a lead from the + of the battery to touch the F of the dynamo briefly. Engine running and the other dynamo lead off.
Suggestions?
Thanks,
Dorien
2
Suggestions?
Thanks,
Dorien
Hi Guest!
