tr 3 horn mounting
emmett1010
Hello All:
I recently got some original windtone horns, and don't know where, and how they mount.
I'd like to mount and wire them before I put the front apron back, but I can't even guess where they need to go.
I've tried looking for pictures, but no luck, so I must rely again on thr "experts".
Thanks for the help,
Emmett Dearing, TS17221LO
Below where the brackets stick up on the fender for attaching the apron is a small ledge. There are two 1/4"-28 threaded holes there. This is where the horns attach. If you have the radiator in and the brackets attached, the horns are under that bracket. If no one posts a pic, I'll do that when I get home, as I have some pics of that area without the apron on. BTW, IIRC each horn will only fit on it's respective side with the horn outlet facing forward.
Thanks Art:
It's like everthing else; Simple when you know how--I had noticed those holes, but kept on looking around the steering linkage area.
Emmett
