TR5/TR250 TR-250 Brake Differential Pressure Valve/Switch
angelfj1
The connector plug for this switch on my TR250 is totally perished. Does anyone know of a source for the connector. The valve and switch are OK. I only need the connector (plug) which fits into the top of the switch.
Thanks,
Frank
TR-250 CD1510LO
TR-3A TS58476LO
Re: TR-250 Brake Differential Pressure Valve/Switc
British Wiring should have it. Talk to Leslie. She co-owns the business with her husband. If they don't have it, it ain't available.
Bill
Get them from a Ford dealership or used at a salvage yard. Other makes also use them but don't remember who.
Don
Do you mean the actual female bullet connector on the end of the black and white wire that plugs into one of the "male" prongs on the PDWA switch? I got one from VB. Or do you mean the rubber/plastic protective cover that the wire goes through, and that fits over the end of the PDWA switch where the wire goes in? I also got one from VB -- if you check out their catalog, they've got a section on electrical stuff -- I think it's the rubber cover for a blade type connector. Worked nicely.
Good luck! /ubbthreads/images/graemlins/smile.gif
