My transmission has been out of my car for a few years while I'm doing a frame up restoration and now's a good time to fix my 5-speed.
Transmission guy says he can't see anything definitely wrong with 5th gear and the slider and as a precaution since the transmission is apart he suggested replacing those two items.
(chaalenge has been trying to find the right parts without knowing what year trans is from. It is however from a Supra.
Anyone have a similar problem??
Also, how can I tell if my transmission is really one with the 28% 5th gear? There are no identifying marks on the transmssion case that I can find.
I have a 3:54 rear end ratio on my BJ8. Do I need a special speedo gear to replace the one that came with the trans? I also had the original speedo rebuilt by Nisonger before the transmission was installed in 2007. I told them I had a 3:54 rear axle ratio when they rebuilt the speedo.
Thanks,
Thanks,
Hi Guest!
