Decided to find out why my choke knob is so tough to pull out.
Pulling on the knob *as hard as I can*, it slowly comes out about 3/4 inch. Can't even see the notches in the stem.
Looked at the cable run. No kinks or bends.
Looked at the choke/jet lever connection. Per spec.
Disconnected the choke cable from the jet lever linkage. Choke pulls easily all the way to max. Tried moving the jet levers by hand. They are *hard to move*. Push very hard and the lever finally "yields" and moves full distance.
Reconnected the cable to the linkage, and removed the jet lever return springs. Choke pulls so much more easily, and for a full two inches.
The problem isn't in the cable or linkage.
Even with only one spring connected, the choke pulls very hard. There's some major resistance, I'm thinking in the jet bearing mechanism (?).
So I'm wondering just what is making it so hard for those jet lever arms to move. Linkage is definitely not binding.
Is there something in the jet bearing assembly that can stick and/or cause all that resistance?
Possibly related: previous owner reports he never used the choke.
I realize some folks say the choke is hard to pull - but I'm thinking mine is a much tougher than it should be.
Thanks.
Tom
Thanks.
Tom
